Stevens Web Site
Date:  5-16-2009
Number of Hours:  1.50
Brief Description:  Flap fairing work
Tonight I cut a hole in the left flap fairing so that it would fit around the step. I started by cutting a hole in a manila file folder which fit around the step where it meets the fuselage. Then, I located the holes which attach the flap fairing to the fuselage and punched some clecoes through when the hole fit around the step well. Then, I transferred the template to the flap fairing and located the position of the hole using the cleco holes I punched in the template. Once I traced the hole position in the flap fairing, I drilled some large holes with the step drill and finished it off with a grinder in the dremel tool. As usual, it took some grinding and fitting before it all fit well. Then, I had to drill some more cleco holes through the step weldment where the original flap fairing holes were located. A little massaging and it all looks pretty good. Once I finish priming, and once I get a riveting partner in the shop, I can finally rivet the flap fairings onto the fuselage.
The manila folder template on top and the cut out flap fairing on the bottom
The left flap fairing clecoed onto the fuselage
