Stevens Web Site
Date:  4-29-2009
Number of Hours:  1.20
Brief Description:  Back on the project, glued in the vent scoop under
Finally back in the basement working on the plane after Sun-N-Fun. I riveted in the last nut plate for the inboard wing fairings for the left wing. Then, I used proseal to glue in the NACA vent scoop under the wing. In order to hold the scoop to the wing surface while the proseal dries, I used painter's tape and a piece of aluminum, bent over to act as a spring.
NACA vent scoop under the left wing
Note the piece of aluminum bent over on the left side of the hole, to hold the vent into place
