They said this would be mind numbingly boring. It wasn't that bad. I used the scotchbrite wheel to debur the flanges of the wing and tank ribs. I then installed the smaller scotchbrite wheel into the drill press to debur the lightening holes. Vicki took the pictures.
Using the wheel to debur a nose rib flange
Using the smaller wheel to debur the lighening hole in a rib
