I finished filing out the aileron pushrod holes in the rear spar doublers and then fitted and drilled the rear spar wing root doublers. I then deburred the 5 jillion holes and dimpled the appropriate flange holes. Now the rear spars and doubler fittings are ready for priming and riveting.
