Stevens Web Site
Date:  10-26-2005
Brief Description:  Final assembly of trim tab
I finished the trim tab by back riveting the skin to the bottom of the spar (not as much a problem as I had anticipated, it was fairly easy to peel back the top skin to get at it) and clecoing the hinge on as I fit it to the elevator. A little jiggling and it all lined up perfectly. I then set the rivets in the side tabs (the plans call for flush rivets, but there is no way to dimple the side tabs, so I used round head pull rivets instead. There should be no clearance problems with the elevator since I fabricated the "mini end rib" instead of bending the tabs on the elevator itself. I then set the rivets on the top of the trim tab spar. In the process, I bent the hinge loops a little and had to bend them back so that the wire could be reinserted into the hinge loops.I then bent the bottom skin of the tab just a little so that it will clear the bottom of the elevator skin. I reattached the trim tab and it all looks straight and beautiful.Next, I mounted the trim tab motor onto the access door with flush rivets and screws. The whold assembly will not go into the access port and I see that I will have to trim about 1.4 inch off of one spot to get it to all fit in. Dan Checkoway had this same problem and used that same fix.
Trim tab from bottom
Top view of trim tab
