Tonight I finished up the mid cabin consoles. I riveted the little side triangles into the console covers and then gave them a fresh coat of paint to cover the rivet heads. I also riveted in the doubler plate for the fuel selector valve. The only thing I am waiting for to install the fuel selector is the nut plates that hold the screws which fasten the valve to the console cover. Finally, I started to install the throttle quadrant into the throttle console. The top plate does not fit right. I may order a new one so that I can drill it to fit better.
