I thought that I would primer all of the elevator parts tonight, but I never got to it. First, I read the next steps in the plans and found out that I should have countersunk the holes on the top of the trim tab spar instead of dimpling them. Ut oh. I smushed the dimples out of the top of the trim tab spar with the flush set and the squeezer and then countersunk the holes.Then I turned to the trim tab servo setup. It took me a while to noodle out the electric trim tab servo setup, but I finally understood it. I drilled and dimpled the trim tab access door to fit the servo brackets. I then spent the rest of the night reading ahead in the plans to see what it is going to take to bend the tabs in the trim tab well.
