Brief Description: Sam and I work on miscellaneous fuselage stuff
Sam Beale came over and we tackled some miscellaneous projects of the fuselage. First, we dismantled the forward baggage compartment (it all comes out with screws) and then we set some of the last rivets in the side fuselage skins at the top longeron. Those rivets were a real bear because the bulkheads they attached to did not come right up to the skins. In the end, the rivets were not real pretty on the inside, but I think they will hold. Then, we began masking off the inside of the fuselage so that I can later paint the cockpit with finish enamel.
