Brief Description: Working on the forward baggage bin and cutting an
After all of the excitement with Jamie's engine start yesterday, I was itching to get back in the shop. I worked drilling and deburring all of the nutplates for the forward baggage bin panels. They are all removable, so I will have to place several nutplates. I also took the plunge to modify my baggage bin bulkhead to provide for an access door so that I can later get to the back of the instrument panel. After much planning and head scratching, I finally started drilling and cutting. I now have the opening cut out. I will have to get some .063" thick aluminum to act as a doubler for the opening. I will also make the door out of .063.
Smoothing the opening cuts for the baggage bulkhead door
This is how the opening will look on the fuselage, looking aft
