Brief Description: Fit forward bulkheads and gussets
Tonight I got a later start because I had to fix a toilet. Oh how the mighty have fallen. Working on a 200 mph aircraft one day, a toilet the next. Thankfully, the airplane project was less smelly. Tonight I fit, drilled and clecoed the forward bulkheads on to the forward skin and the top and bottom longerons. Then, I removed the forward side skins and fit two gussets between the firewall angles and the bottom middle longeron. Drawing 30A in the plans is a little confusing and I am not 100% certain that I fit the gussets right. I am e-mailing a photo to Vans to see if this is the right configuration.
