Brief Description: Finished rear seat belt brackets
Tonight I finished the rear seat belt brackets by fabricating the smaller aluminum angles and drilling them to the fuselage. Then, I deburred them and primed them before riveting two of the three pieces together. The final angle is bolted to the other bracket through the lower longeron after the skins are riveted on to the bulkheads. Last, I figured out how the middle bottom skins go on to the fuselage skeleton and placed a few clecoes just to tack them on. Later, I will confirm the configuration and then drill them to the fuselage.
The completed rear seat belt brackets
The bottom middle skins, tacked on with a couple of clecoes
