Brief Description: Sam Beale and I drill on the right side aft skin
Tonight Sam Beale came over and we tackled the aft side skins. Previously, I had fit the lower and mid level longerons to the aft bulkheads. Remember, the lower longerons are at the top now since the fuselage is being build upside down. We had to move the bulkheads around a bit to get all of the holes lined up, but it worked out great. Sam would drill and I would cleco. We only drilled out every other hole, so I will go back and drill out the rest of the holes later.
The fuselage bulkheads with the lower and mid level longerons clamped in
Sam Beale drilling on the right side aft side skin
