Stevens Web Site
Date:  6-14-2005
Number of Hours:  3.50
Brief Description:  HS drilling and blue plastic removal
Drilled the inboard rib attachment to the forward spar using the #30 bit in my dremel tool. Then, I rechecked to make sure all of the holes in the skins were drilled and took the whole thing apart. I deburred the skeleton (very tedious) and then removed the plastic from the insides of the skins. I then removed strips of plastic from the holes in the outside of the skin, using a pencil soldering iron (with the tip rounded off so it would not scratch the skin). Next, I will deburr the skins and commence to dimpling
Left HS with skin clecoed on
