Brief Description: Priming bulkheads and fabricating floor ribs
I had the opportunity to work on the project most of the day. It was cool but clear outside, so I started off by priming all of the bulkheads I have been fabricating over the past few weeks. Then, I riveted two of the bulkheads and resumed work on the 806 bulkhead, which holds one end of the floor ribs. The floor ribs are fairly complicated because they have reinforcing angles and seatbelt brackets riveted to them. I worked on the two inboard floor ribs most of the day. Finally, I fabricated the bracket which will hold the passenger air vent.
Floor ribs which will attach to the 806 bulkhead
Passenger air vent bracket which will attach to the right seat belt bracket
