Stevens Web Site
Date: 9-25-2006
Number of Hours: 3.50
Brief Description: Hung the left flap (take 3)
As you may recall, I first hung the left flap before getting all of the spacers and washers in the aileron hinges, resulting in a botched effort. My second attempt at hanging the left flap (with a new hinge half) was much better. However, once I riveted on the bottom skin, I saw that the flap brace (to which I was to rivet on the flap hinge) had considerable give in it, resulting in (you guessed it) another botched attempt to make the flap fit. Now older and wiser, tonight I fit the flap to the flap brace which is not lined up with the bottom wing skin. It was a tight fit, but it worked. The alignment is much better than the first two attempts. It only cost me another hinge (which I have ordered from Vans). Last, I riveted on the nutplates for the inspection covers and I drilled, deburred and dimpled the inspection covers themselves to receive #8 screws. The only thing left to do is to glue in the pvc electrical wire conduit and to begin working to finish the right wing.
Left wing, el finito
The inspection cover and the hole for the pitot tube
