Tonight I routed the aluminum 1/8" pitot line. I also used the tubing flaring tool from our EAA chapter tool library. There is a bulkhead fitting on the inboard wing rib and the line is routed through the 7/16" holes Sam and I drilled. The pitot line is bent a little where it goes behind the aileron drive bolted to the spar for clearance issues. I need to buy an AN815-4D untion to connect the line to the pitot tube. I also need to buy some 14 ga. wire to wire up the heated pitot tube and some coax for the nav antenna I plan to put in the left wing.
Bulkhead through fitting for the pitot line
Pitot line ready to join with the pitot tube (I need an AN815-4D fitting)
Pitot line routed for clearance from the aileron drive
