Brief Description: Final prep of top right wing skins
I had a long and bitter day in court today, so I came home beat. I tried to cleanse my soul by going into the shop and turning on the classical music. It worked. I did the slight countersink thing for the top skins for the right wing. Then, I began clecoing on the wing skins, thinking to myself that this would be the last time I would cleco on these particular skins. Pride goeth before the fall. After setting all 3 jillion clecoes, I realized that I had to taper the upper corners of the inboard and outboard wing skins so eliminate the bump at the top where the skins overlap. DOH! Oh well, the music was good and the pleasure in life comes from the journey. So, I journeyed the 3 jillion clecoes back into the can and took the wing skins off to taper the appropriate places. Time to call it a night and hope I can sleep without thinking about the second day of trial.
Doing the slight countersinking of the right top wing skins
