I was waiting to rivet the longerons along the canopy. I thought I was supposed to hold off on those. I realized today that that was only for the tip-up canopy.
Spent a couple of hours riveting those in.
Test fitted and taped the windscreen. Then set elevation of rollers and drilled those out.
Set windscreen and drilled that out too. Figured out the shim requirements at each location.
