Steven's RV-9A
RV-9A
interior
interior panels and seat belts
Put numbers on plane and experimental decal.
Tested ELT. Used handheld on 121.5. Waited until 1855 and tested. Worked great.
Finished installing interior body panels excepting luggage side panels and rear panel blocking tailcone.
Installed seat belts/shoulder harnesses.
Brake leak problem is solved - no more leakage.
Finally figured out routing of scat tube. Needed to make a couple of brackets to exhause. Finally happy with it.
RV-9A Home
1014
367
356
