Stevens RV7 N617R
Date:  4-3-2006
Number of Hours:  1.00
Brief Description:  Match drilled the , HS-412,& HS413
Match drilled the HS-412PP , HS-413PP ,HS411APP, and HS411BPP elevator hinge brackets to the rear spar assembly. I also clecoed the HS-411APP and the HS-411BPP brackets around the VA-146 bearing. I clecoed this assembly to the spar. The next step is to match drill the HS-411APP and the VA-146 to the HS-411BPP.
