Stevens RV7 N617R
Date:  3-26-2006
Number of Hours:  2.20
Brief Description:  The HS-609PP spar reinforcement bar.
Smoothed the edges of the HS-609PP spar reinforcement bars with a scotchbrite wheel. Did some work smoothing the surface of both bars. I need to work a little more on that later. I also used the scotchbrite wheel to smooth the edges of the HS-603PP spar channels. I rounded the tips on the spar bars. Finished sanding the edges to allow clearence of the bends on the HS-603. Clecoed the two HS-603 to the spar bars to check the fit.
