Brief Description: Matched drilled the HS-411APP, 411BPP & VA-146
Matched drilled the 6 holes in the HS-411APP, 411BPP & VA-146. The next step is to prime the VA-146, and rivet the assembly together. These will be the first rivets in the plane. After taking the assembly apart, I discovered that I had misaligned the holes in the bearing. I ended up with twice as many holes. Well, that was my first screw up. At least it was a cheap and easy fix. I have ordered another VA-146 bearing.
