Brief Description: Horizontal Stabilizer Frame ready for skins.
All parts have been cleaned with alcohol, acid-etched with Alumiprep, and Alodined prior to being primed with Zinc-Chromate primer. My local source for Zinc-Chromate can't seem to decide which colour to keep in stock, so I had to use both green and yellow. I used solid rivets to attach the Main Spar Channels to the Main Spar Fitting, blind rivets as per plans everywhere else. I used a full size pattern plotted on mylar to line everything up, and the milled surface of our CNC router table to keep everthing flat.
