Brief Description: Nose rib and front channel attachment
Riveted the doubler to the front channel. The solid AD5 rivets turned out pretty good if I do say so myself! Riveted nose ribs 1-5, starting with 5 first, to the spar. Attached the front channel next. Pependicular alignment with the spar wasn't an issue yet. It will be though when I put the skins on. I then moved out and attached ribs 7,8,9 and 10. Pretty straightforward. ** NOTE- I realized later that nose rib #10 cannot sit against the spar. It needs to be pulled out some and placed in line with the other nose ribs. This is probably why the "L" angle for it is wider than the other ones.
