Brief Description: Right wing spar extension removed
After reworking and leveling my build table, I realized that the spar extension was not installed straight in relation to the rest of the spar. I drilled out the rivets, removed the mounting bolts, then removed the extension frome the main spar. I called Zenair to order new pieces for a replacement spar extension. *** Note: As of 6 Jan 2011 I have still not received a call back from Zenair. I'll call back tomorrow and see what the hold up is...
