Brief Description: Upper bellcrank support placement
Once the bellcrank support was in place, I just figured where the holes had to be in order to keep proper edge spacing and drilled them. The bellcrank stop was easy, and I placed it after the support was on so I could just butt the two up against each other. I undersize drilled the holes first as well. The holes were drilled into the support first, then into the spar itself. That's why I undersized them, so I didn't enlarge the holes too much.
