Brief Description: Upper bellcrank support placement
I installed the upper bellcrank support only at this time becasue I couldn't get underneath the bottom one to drill the holes. The holes for attachment to the ribs will be slightly different becasue I installed the ribs upside down as mentioned earlier. Zenair said it wouldn't be a problem though and it won't interfere with the bellcrank's operation. If you compare the first picture to the diagram on 640-V-8 you can see that the holes are higher than what the plans call for. The bellcrank and support are in the same positions they would be though. The upper one is placed basd on the bottom upper edge of the top of the spar as can be seen in the second pic. In the last pic, I used a square as seen to make sure the support was perpendicular to the spar.
