Pretty straigthtforeward on the gussett installation. The only area to watch out for is the forewrd edge where it comes to a point. If you mark and drill the holes as the plans tell you for where it will attach to the spar, the foreward edge will not have enought edge clearance. I adjusted it foreward some so the leading edge had the proper spacing.
