Debur trim tab components; prime and rivet assembly, used cherry msp 32 on bottom of trim tab, I could not get a good rivet set for those rivets. rolled the leading edges of the elevators, this task was not as simple as the rudder due to the tighter radius. worked hard to get the edges as close as i could, started to get some bending at the spar so i stopped further rolling, i was able to get these in position and clecoed.
