- Riveted the rudder trailing edge. It has a little bit of a bow, but it's straight within Van's specs of 0.1 in... it also has a couple of smileys where the backrivet set hit the skins. I don;t think it's a big deal; I'm going to have Dick Koehler (EAA Tech Counselor) come over to take a look at it. - Rounded the rudder trailing edge and pop-riveted it together. It wasn;t too bad, but it was tougher than I thought it would be! - Installed and adjusted the rod end bearings. - Couldn't resist - hung the rudder on the HS... SWEET!
