- Match-drilled the rudder skeleton pieces - Fabricated the rudder horn brace - Primed the rudder stiffeners - Started backrivetting the stiffeners onto the skin. Got the first 8 rivets set, then realized that I had left the plastic on the inside of the skin! Drilled out the rivets, and started again after removing the plastic.
