Brief Description: Dimpled skins; worked on skeleton
- Dimpled all elevator stiffeners - Dimpled both elevator skins for the stiffeners - Assembled the end rib and counterweight rib for both elevators. - Drilled the counterweight screw holes - Started putting the skin on the skeleton, but then stopped since the stiffeners aren't on yet and the skins aren't bent.
