Steves S-20 Build Site.
Date: 4-14-2019
Number of Hours: 6.00
Brief Description: Installing the Glareshield Pad.
I the started the glareshield pad by taping some kraft paper in place and installing the windscreen. I was able to trace around the windscreen components and develop a template for the shape of the material to be cut.
I taped off the area to be glued and used the outside of my template clecko'd in place to determine where to trim the tape.
I used DAP Landau contact cement for the glue. This stuff sticks like nobody's business, and although it can be hard to find, I have had excellent long term results with it.
In a past project, I had used some 1/8" "scuplting foam" under a dash pad, and it worked well. I installed the foam, and then sanded down the rivet areas. It worked OK, but not as well as I had hoped. Once the top layer of the foam was sanded, the middle would tend to ball up and gouge out, leaving craters. For as excited as I was to use this foam, it came out pretty well, but I think I would do something different next time.
On top of the foam I glued a piece of the same leather look lightweight vinyl I used on the kick panels.
I found out the hard way that trying to glue the entire glareshield area at once is a recipe for disaster. I used waxed paper to keep things from sticking until I could make sure I had them placed correctly, but a large portion of the paper tore off under the foam pad, and I ended up destroying the pad trying to get it out and had to start over. For the second time around I glued just the center portion between the down tubes, and then glued the outer portions after. This resulted and vast decrease in the number of "F-bombs" that flew through the room....
Since I had used the foam, the edge trim tended to want to push my vinyl out of place instead of slip over it. A butter knife borrowed from the kitchen worked to push the vinyl into place as the trim was installed.
This took a good part of a Saturday for me to accomplish, but it was certainly exciting to take in the finished results.
My remaining tasks list is starting to get pretty short.....
Developing the paper template.
Outside of template to show area to be glued.
The finished product.
