Randy's 750 Cruzer Project
Date:  3-21-2020
Number of Hours:  3.00
Manual Reference:  C75-FA-1
Brief Description:  Cut & drill support for fuel header tank
It is my intention to use the 2.5 gallon fuel header tank from Viking Engines. I will mount it behind the baggage area on the passenger side.
I am replacing the existing L angle C75F18-1 on the right rear fuselage side with a 3/4" x 3/4" aluminum tube.
Today I cut the tube to length and angled the botton end so that it fits with the bottom longeron. Next I used the existing L angle as a guide to mark the top and bottom holes. I then drilled the top and bottom holes on the drill press, after which I clecoe'd the tube in place and drilled the remaining holes.
