Todd’s RV14a
RV14a
Fairings
3-17-2020
Fairings
During pandemic decided to work on all the fairings. Used filler in some areas to fill in the joints. The fiberglass is thin so to keep the pop rivets from pulling thru I placed 8 mm washers on the inside to give it a bearing surface.
RV14a Home
683
AFT Fuselage
Aileron Actuation
Aileron Both
Elevator
Empange Attach
Fairings
Firewall
Flaps
Flight Controls
Fuel
Horizontal Stabilize
Instrument panel str
Interior Paint
Left Aileron
Left Wing
Left wing fuel tank
Left wing Leading ed
Lighting
Magnetometer mount
Pitot
Right Aileron
Right Fuel Tank
Right Wing
Right Wing leading E
Rollbar
rudder Pedals
Spar
Vertical Stabilizer
Wing bottom skins
Wing bottome skins
Wing Wiring
