Todd’s RV14a
RV14a
Right Wing leading E
11-30-2019
Right wing leading edge
Finished up the right wing leading edge. Drilled the tie down hole as instructed. Wating to install landing light later on in build. Will come back to that later.
Clecoed the leading edge to the spar and riveted it per instructions.
RV14a Home
683
AFT Fuselage
Aileron Actuation
Aileron Both
Elevator
Empange Attach
Fairings
Firewall
Flaps
Flight Controls
Fuel
Horizontal Stabilize
Instrument panel str
Interior Paint
Left Aileron
Left Wing
Left wing fuel tank
Left wing Leading ed
Lighting
Magnetometer mount
Pitot
Right Aileron
Right Fuel Tank
Right Wing
Rollbar
rudder Pedals
Spar
Vertical Stabilizer
Wing bottom skins
Wing bottome skins
Wing Wiring
