Todd’s RV14a
RV14a
Left wing Leading ed
3-30-2019
leading edge outboard
17-07 Clecod the ribs into place. Clecod the splice strip and landing light bracket into place.
17-08. Installed stall warning assy. Adjusted as required.
17-09 Final drilled tie down location. Riveted eveything together. looks good.
17-08. Attached the leading edge to the fwd spar as called out.
RV14a Home
683
AFT Fuselage
Aileron Actuation
Aileron Both
Elevator
Empange Attach
Fairings
Firewall
Flaps
Flight Controls
Fuel
Horizontal Stabilize
Instrument panel str
Interior Paint
Left Aileron
Left Wing
Left wing fuel tank
Lighting
Magnetometer mount
Pitot
Right Aileron
Right Fuel Tank
Right Wing
Right Wing leading E
Rollbar
rudder Pedals
Spar
Vertical Stabilizer
Wing bottom skins
Wing bottome skins
Wing Wiring
