Todd’s RV14a
RV14a
Left Wing
1-20-2019
Left wing buildup
Continued with left wing spar and aft ribs. Installed all aft ribs and bolts. Torqued to 28 in lbs plus run on torque of 14. 42 in lbs total. Riveted ribs into place with AD4704 rivets as per step 3 and 4.
Riveted the fwd tab on 7 most inbd ring ribs.
RV14a Home
683
AFT Fuselage
Aileron Actuation
Aileron Both
Elevator
Empange Attach
Fairings
Firewall
Flaps
Flight Controls
Fuel
Horizontal Stabilize
Instrument panel str
Interior Paint
Left Aileron
Left Wing
Left wing fuel tank
Left wing Leading ed
Lighting
Magnetometer mount
Pitot
Right Aileron
Right Fuel Tank
Right Wing
Right Wing leading E
Rollbar
rudder Pedals
Spar
Vertical Stabilizer
Wing bottom skins
Wing bottome skins
Wing Wiring
