10-23 Routed the UAT cable thru the bulkheads and secured with cables.
10-24. Installed the ELT cable as required and secured.
10-25. Installed WH-00057 cables. Decided at the moment I dont like the molex connectors. May change everything to Cannon plugs. Removed some of the 00057 cable and installed some 3 wire shielded cables to the back. Going to install flyled lights and they recommend shielded just in case. Also where the cables lay in the longerons I can see there will be some chafing going on. Installed some of the other wires as shielded also even though I may not ground it. Just to give it some extra protection. Instead of routing the wires thru the bulkhead channels I ran them of through the lightning holes. Much better.
10-26. Ran phone cable also for the Elt, and secured.
