Todd’s RV14a
RV14a
Spar buildup
Step 1 13-03. Final drilled the flange holes to #40. Countersunk several hundred nutplate holes on both flanges.
Step 4. Riveted nutplates for fuel tank skins to spar. Riveted wing access nutplates
Step 7-9 Countersunk skin and rib flanges on spar.
13-05. Steps 1-4 Final drilled spar doubler and riveted 3 nutplates to spar assy. Final drillled aileron bellcrank brackets and bolted to assy.
RV14a Home
683
AFT Fuselage
Aileron Actuation
Aileron Both
Elevator
Empange Attach
Fairings
Firewall
Flaps
Flight Controls
Fuel
Horizontal Stabilize
Instrument panel str
Interior Paint
Left Aileron
Left Wing
Left wing fuel tank
Left wing Leading ed
Lighting
Magnetometer mount
Pitot
Right Aileron
Right Fuel Tank
Right Wing
Right Wing leading E
Rollbar
rudder Pedals
Spar
Vertical Stabilizer
Wing bottom skins
Wing bottome skins
Wing Wiring
