Todd’s RV14a
RV14a
aft fuse
Finished clecoing skins onto bulkeheads section 10-14. Installed stringers. Dimpled #27 holes for access plates.
10-15. Removed hatched area on F1479 Bottom skin. Had to adjust slightly to get it to lay under the 1472 skins. Dimpled and final drilled holes where indicated on 10-16,
10-17 Installed 1479 bottom skin and clecod. Pain in the butt.
RV14a Home
683
AFT Fuselage
Aileron Actuation
Aileron Both
Elevator
Empange Attach
Fairings
Firewall
Flaps
Flight Controls
Fuel
Horizontal Stabilize
Instrument panel str
Interior Paint
Left Aileron
Left Wing
Left wing fuel tank
Left wing Leading ed
Lighting
Magnetometer mount
Pitot
Right Aileron
Right Fuel Tank
Right Wing
Right Wing leading E
Rollbar
rudder Pedals
Spar
Vertical Stabilizer
Wing bottom skins
Wing bottome skins
Wing Wiring
