Seperated the F1429 Bellcrank ribs. Dimpled all said holes. Final drilled battery angles. Clecod the whole assy together. Deburred and primed. Riveted assy together. Installed nut plates on the 1406B Bulkhead.
10-13. Riveted battery angles to the bellcrank assy. Dimpled all the holes of the bottome skin and primed F1478. Clecod bulkheads to the bottom skin. Clecod J-channel to bottom skins.
