Todd’s RV14a
RV14a
Right Elevator
Continued and scuffed the rib locations and trailing edge area with aluminum oxide sandpaper. Primed parts and skins with SEM etching primer.
9-16...Riveted the 906 root rib to the fwd spar as required. Riveted the 903 and 904 counterbalance ribs together as required. Easy.
Riveted the hinge reinforcement plates and nutplates.
9-17. Riveted the counterbalance skins. No twist. Looks good. Step 2. Riveted the 605 Elevator horn to the front spar.
Step 3. Clecod the 1008 ribs and shear clips to aft spar and riveted.
RV14a Home
683
AFT Fuselage
Aileron Actuation
Aileron Both
Elevator
Empange Attach
Fairings
Firewall
Flaps
Flight Controls
Fuel
Horizontal Stabilize
Instrument panel str
Interior Paint
Left Aileron
Left Wing
Left wing fuel tank
Left wing Leading ed
Lighting
Magnetometer mount
Pitot
Right Aileron
Right Fuel Tank
Right Wing
Right Wing leading E
Rollbar
rudder Pedals
Spar
Vertical Stabilizer
Wing bottom skins
Wing bottome skins
Wing Wiring
