Continued with the rudder build. Clecoing all parts for fit and final drill. Clecod rudder tips and all the shear clips as per steps 1-2. R-00914A-G were fit. The tail ends dont exactly overlap 100% but should as it gets clecoed. Final drilled trailing edge. Began clecoing the right and left skins on. Fit fairly well except for the right skin down at rudder horn...may need slight trimming.. R-903 counterweight rib required slight adjustment to allow the nose skin to wrap around. Will begin final drilling and dimpling skin Saturday then disassembly for final prime and debur.
