Brief Description: Port Wing Stub Structure, and a Little Extra
I finished the substructure for the port side wing stub, and installed the mount for the port aileron bellcrank as well. Next up is building the bellcranks and connecting this one to the rear stick. I also built a mount for the Flyboys throttle quadrant I am using, and got that installed. Lastly, I built the fuel line manifold, although I won't install it until the fuel line caps to keep construction debris out of the lines arrive.
