Brief Description: Package Shelf, Primer, Rudder Lines
I've gotten the package shelf installed, with the aft end riveted under the F8 bulkhead, and the fore end bent upward to conceal the additional support brackets for the rear rollover supports. I've also primed the package rack and cockpit. Once that's firmed up enough I can put down the final coating for noise dampening, waterproofing, and anti-slip. I also ran the PE rudder lines from F11 to F2, and revised the fitment to use rubber grommets at each bulkhead.
