Thatcher CX-5 Build Log
Date:  6-2-2018
Brief Description:  Gussets Installed
Most of the day was wasted trying to fly. The aircraft I'm renting failed preflight. Again. It's a twelve year old Remos GX with fuel leaking from the sump, Dynon errors on every flight, brake problems, and now the engine quits at idle. And it took most of the day to fill out squawk report paperwork and get everything buttoned up. So I came home, and at least got the four gussets attched to the longerons. Once the firewall is installed, these will help spread the load out over a larger area. And I feel better for having done something productive with my day.
