Thatcher CX-5 Build Log
Date:  7-19-2020
Number of Hours:  5.00
Brief Description:  Rear Canopy Latch and Weatherstrip
Attached are pictures of the rear canopy, with the compression weatherstipping fitted between it and the F7 Bulkhead. I've also built a bracket for a draw latch, and installed it to hold the rear canopy closed in flight. I've hand-painted the interior rivets on the rear canopy; since the white epoxy was sprayed prior to final assembly there were some twenty-six rivets that joined the upper, right, and left canopy pieces. Those are now also painted white epoxy.
I started work on the front canopy, but only just.
