Completed the port side brakes, filled, bled, and tested. Tried out some fitment changes, and reversed one of the screw/nut assemblies on the rudder pedals to get better clearance from master cylinder fittings.
Also got the control rods drilled out for the stops and control sticks, and got everything epoxy coated. Once they dry I will be able to assemble them.
