Lots and lots of fiddly bits, some big bits. I got the upper port side tailcone skin made, primered, and installed. The brake master cylinders have been mounted, after performing a little surgery on the rudder pedal arms to accomodate the clevis from the brakes. The aileron control arm that runs from the front seat controls to the rear seat controls has been installed. That required a lot of reaming out of the control arms. Also the air brake control shaft has been installed; in the third picture it is just barely peeking out from under the passenger seat at the top of the image. I also mounted the tire on the nose wheel. All in all, lots of bits and bobs all over the plane slowly pulling together.
After another week-long work trip coming up, I'm looking forward to getting back and getting last piece of skin on the tailcone, and getting the control sticks mounted both fore and aft.
